configure dot1p type
configure dot1p type dot1p_priority {qosprofile} qosprofile {ingress-meter [ ing_meter | none ]}
Description
Configures an 802.1p priority to QoS profile mapping for the specified ports.
Syntax Description
dot1p_priority Specifies the 802.1p priority value. The value is an integer between 0 and 7.
qosprofile Specifies a specific QoS profile. The value range is QP1 to QP8.
ingress-meter Ingress rate-limiter meter.
ing_meter Ingress rate-limiter meter name.
none Dot1p examination rule has no ingress-meter (default if ingress-meter is unspecified).
Default
The default mapping of each 802.1p priority value to QoS profile is shown in the following table.
Table 1. Default 802.1p Priority Value-to-QoS Profile Mapping
802.1p Priority Value ExtremeSwitching Series Switches Default QoS Profile
0 QP1
1 QP1
2 QP1
3 QP1
4 QP1
5 QP1
6 QP1
7 QP8
Usage Guidelines
An 802.1p priority value seen on ingress can be mapped to a particular QoS profile and with specific bandwidth management and priority behavior.
You must create the QoS profile first, using the create qosprofile [QP2| QP3 | QP4 | QP5 | QP6 | QP7] command, to map the 802.1p information to QoS profile 2 through 7.
SummitStack Only
You must create the QoS profile first, using the create qosprofile [QP2| QP3 | QP4 | QP5 | QP6 | QP7] command, to map the 802.1p information to QoS profile 2 through 6. You cannot create QP7 in a SummitStack.
The following commands reassign (from the default) the QoS profiles associated with 802.1p priority values 1 and 2:
# configure dot1p type 2 qosprofile qp2
# configure dot1p type 1 qosprofile qp3
The following examples use the ingress-meter option:
# configure dot1p type 1 qosprofile qp5 ingress-meter ingmeter0
# configure dot1p type 2 qp3 ingress-meter ingmeter2
# configure dot1p type 3 qp4
This command was first available in ExtremeXOS 11.0.
The ingress-meter, ing_meter, and none options were added in ExtremeXOS 16.1.
Platform Availability
